Hi, is there a UI setting not to open views in a new tab all the time? I would very much just want to switch views in my UI when clicking project browser and not have every view opening a new tab all the time and/or without having to close views that is. Been looking a while for settings, but I don't think it's possible, but maybe someone knows.
Gelöst! Gehe zur Lösung
Gelöst von indiana_j0nes. Gehe zur Lösung
I'm not sure that there is! However that would be an awesome toggle to have access to depending on your work flow.
Well You can set a shortcut for Close Inactive Views..
That would be a workaround..
Cheers, K
Kunal Tuljaram Gaidhankar
Thanks that's a reasonable solution I guess, marked it as solution. However I would still appreciate the UI functionality, for the idea forums. If you count lost time for all Revit users closing windows I'm guessing it adds up... ![]()
True, i am sure there must be a way to disable the tab feature and let Revit refresh the same window with a new view instead. The tab feature is new since 2018, it was a requested feature from 2017.
Maybe you can add this to the wish list and garner votes for it to be implemented.
Cheers, K
