Best users of Revit LT 2018,
Signing up for Revit LT 2018, I was told i could also edit SKP files in my Revit LT 2018. But i didn't succeed yet.
Import SKP will not open my files. They are saved as a V7 or V8 file. Still it is not working.
Does anyone know how i can edit it?
greatings Mariska van der Velde
Revit/Revit LT can import/link in a SKP file. Go to Insert Tab of Ribbon, Choose Link or Import CAD. When window opens up...go to Files of Type and change to SKP. Select SKP file from your drive location. Choose options for importing/linking. Click OK.
You can change how the SKP looks in Revit via the Visibility/Graphics Dialog Box (VV/VG). You can snap to the content and select the content depending on how it was built. Revit typically treats the SKP as a single entity but you may be able to Tab into the objects of the SKP file to change it's appearance via Override in Graphics by Element/Category.
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
can you send the file to me? I want to see if the issue is with the SKP file or your software or your hardware. If you send the file to me and my workstation can see and import/open it, then the file is fine and the issue lies with your Revit software and/or workstation. If I cannot open/import the SKP file, then the issue is with the SKP file.
send to:
https://www.dropbox.com/sh/ywx89igylzhxomu/AACfLUYhBNVDxj-BCNLSE5Ipa?dl=0
Hi @Anonymous
Welcome to the Autodesk community!
Can you try to export the SKP file to a CAD dwg and then link that dwg in Revit?
Let me know if this works.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
