Open a IFC file
Open a IFC file
Open a IFC file
Once the exportation .rvt to .ifc is done, is it possible to open the IFC file without Revit?
Is the software Solibri functional ?
SezaiErcan
Hi @Anonymous
.ifc is a file extension which can be used by BIM Programs. You can open IFC files with all the BIM programs. For example, I have imported IFC files ( which i exported from My Revit Projects ) to TEKLA Structures (basically,  a steel structure modeling program with BIM base ) and it worked.
I have heard about Solibri Software but i haven't used it yet. It should open IFC files but i think you can't make changes but i'm not sure at all because as i said i haven't got a chance to use it yet .
Hope that these informations help.
Regards.
Thank you for your answer, but now I've other questions:
To use your example,  if I import IFC files to Tekla, and I work on it, now:
- what can I do with my Tekla work? is it possible to export my work to IFC to reinject my work on the project?
- If I noticed an error and I want to add a comment or a note, what is the simplest way to do it?
- if the architect made a modification on the model, does it change the file ifc? Is the file ifc linked with the revit file?
SezaiErcan
Hi again @Anonymous.
It looks like you are confused . Hope i can answer all the questions you have.
- First of all,  Tekla was just an example. There are a lot of BIM programs which you can use to open IFC files. In Tekla, you can design steel structure systems so that means Tekla is a specialized program about Structural System Design. I said there are a lot of BIM programs which you can use, Just you need to know what kind of program you should use to work on your IFC file. For example , if you need to Design Steel Structure system or If you need Lighting Design , You can use DiaLux or ReLux. It's all about what you need. And You can export what you did on your project to IFC file again and then you can import it to another program. Shortly, Yes it is possible.
I'm not sure about your second question about but i remember that one of the Autodesk BIM360 program do this. I remember it from a presentation and it was looking easiest thing on Earth. I suggest you to search about it. ( Different users from This from can help more effectively maybe ).
If somebody make a change on Ifc file , it does change your Revit model too but you should Reload it from '' Manage Links '' tab. IFC files can be linked to Revit Models.
Once again thank you for your answer.
Yes I just started to work on Revit few days ago so I'm a little bit lost.
I'm gonna make some searches Autodesk BIM360 program.
Regards.
