OOTB LVL-Laminated Veneer Lumber-Section DETAIL ITEM fill region rotation
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
jledgewood409
1711 Aufrufe, 8 Antworten
i am trying to use the Out Of The Box LVL-Laminated Veneer Lumber-Section DETAIL ITEM. when i place this detail item in my model and rotate it the fill region stays in the same direction as it was in its original position. how can i correct this so that the fill region is relative to the detail item? i am attaching a screen shot of what i described.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: jledgewood409
Nachricht 3 von 9
jledgewood409
als Antwort auf: barthbradley
do I need to make this change in the family fill region or in the project fill region?
Nachricht 4 von 9
Nachricht 5 von 9
jledgewood409
by default in the family it is set to 'orient to view'. I have tried all three options; orient to view, keep readable, & align with element. I cannot seemed to get the pattern to rotate with the element. I am attaching the family for your review
Nachricht 6 von 9
I'm not sure what you are trying to do.  The OOTB Glue Laminated Beams-Side.rfa is parametric. Can't you use that one?  It does't use a fill. It ARRAYS a Nested Detail Item Family named "Lamination"  to represent the actual number of layers of laminate.
Nachricht 7 von 9
A drafting pattern's Align with element only works when the pattern is used in model elements such as walls.  See pic below.  You need to use a model pattern for the detail component family if you want it to match the rotation of the family in project.
Nachricht 8 von 9
jledgewood409
I suppose that I could use the glue lam. my structural engineer was calling for an LVL so I wanted to represent that appropriately by using the Revit LVL.
Nachricht 9 von 9
You can copy the family and rename it whatever you like.  All the work is done for you. It's a great family. It'll be the same great family under a different name too.
