only one person in our office has this problem
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
1937 Aufrufe, 9 Antworten
I'm not sure where to start.
Our office has 12 people that work in Revit (2016) everyday. We work with central files through local copies on each computer. All of us in the office can work on files together, except ONE. This one co-working has to work on his projects as stand alone files from the server because the minute one of us gets into his file (the central file) his computer will not let him work on it or save it. We have tried to open "local" copies on his computer but once they are open he can't work in them or save them.
Has anyone else had this problem? How do we fix his computer so we can help him with his projects and not cause him trouble?
9 ANTWORTEN 9
Nachricht 2 von 10
Matt__W
als Antwort auf: Anonymous
Hi, @Anonymous, does either user receive an error message or warning? If so, what does it say? Can you post a screenshot?
Also, please ensure that all team members are working on Revit with the latest updates installed. You can find any available updates on your Autodesk Account Management page at manage.autodesk.com
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Nachricht 3 von 10
alan.quinn
Its most likely not Revit. Try the following:
1. Have this user go to another PC and log in with their network credential, cut a local and try to work. If this works the issue is their PC.
2. Have another user log into this users PC with their network credential, cut a local and try to work. If this works the issue may be the users (one that cannot work in a local) profile.
3. Clear out the Temp folder on the issue PC/user. Windows search, enter %Temp%, open the resulting folder and delete all. Its best to restart the PC first, then clear the Temp, then restart and test Revit again.
4. You may have to flatten the PC as a last resort.
Let us know the results.
Nachricht 4 von 10
Sahay_R
Sounds like a user profile issue.....
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 5 von 10
Sounds like someone has Write Access only to the directory.
Meaning if that person creates a project for the first time, they will always have access.  If someone else creates it, then they can read, but cannot save.
Save a word document in the same directory with some text in there and exit.  Have that user with issues try to open, edit and save that file.  If they cannot save, it is a permissions issue.
I have seen this a few times where the person, or their workstation, were not a member of the proper security group.
Nachricht 6 von 10
als Antwort auf: Matt__W
Ok, it's still happening... here are screen shots of the error messages.
Nachricht 7 von 10
@Anonymous
Do this....go to your P: drive directory you are having issues with.
Right click the folder and select  Properties
Go to the Security tab and click Advanced
Click on the Effective Permissions tab and click the Select button.
Type in the user's name in the box and click Check Names...when found click OK
Check the permissions...Should have access to pretty much everything.
Nachricht 8 von 10
Okay folks, thanks for all of your suggestions... we tried them all and as it turns out we ended up uninstalling and re-installing the Revit on his computer and it is working like it is supposed to...
Thanks again for all your help!
Nachricht 9 von 10
pipapongo0909
hi,
could also have been a username in revit that is set in two pc.
meaning that th user with the problem might have had anothers user setup.
glad you are back on track
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
Nachricht 10 von 10
Viveka_CD
Hi @Anonymous
Glad to hear that your issue is resolved and that the community has been helpful!
See HERE for a clean install of your Revit product.
