Only images printing on titleblock
4 ANTWORTEN 4
Nachricht 1 von 5
cjmyersAJN7F
266 Aufrufe, 4 Antworten
I created a 36x24 titleblock using the template family. I added my updates, logo, images, and text. When I print it, I only see the images, not the lines or text. If I print to a pdf and then print, it works fine. I'm thinking it is printer settings within Revit but cannot figure out where to look. I've tried printing with either Raster and Vector selected.
Additionally, once I get this large size print working, is there a way to scale it to the smaller titleblock sizes I will need?
Thank you,
Carol
4 ANTWORTEN 4
Nachricht 2 von 5
Ilic.Andrej
als Antwort auf: cjmyersAJN7F
You can create different title block families for different sizes.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 5
s.borello
I always create PDF before plotting, had issues with AutoCAD & RVT in the past so this is my preferred practice.  You don't scale in revit...(well not really).  You need to create separate TB families for your different size sheets.
Nachricht 4 von 5
cjmyersAJN7F
als Antwort auf: Ilic.Andrej
duh! i was asking how i can create them from the large format i've already created so i don't have to create from scratch. i guess, is there a way to scale the large format?
Nachricht 5 von 5
cjmyersAJN7F
als Antwort auf: s.borello
ok, that's what i've been doing, printing to pdf. just seems like it should work.
