On/Off grid's visibility base on view scale!!
spahlevan
spahlevan
I would like to be able to see different grids when I am viewing on different scales? Basically make their visibility status scale based.
For instance I have many grids in a project but not all of them are important to see when I am on scale of 1:200 but some other grids get important when I am on 1:50 or 1:25 scale for detailing.
Is it possible to on/off grid's visibility base on view scale?
constantin.stroescu
How I'll do it by using Filters and View Templates:
  • First create a Section Set with all minor Grids that are not necessary to appear on certain View Scale
    • select all the desired Grids and then Manage>Selection > Save and call it with an appropriate name
    • this Name will appear in View >Filters >Selection Filters
  • then from View > Visibility/Graphics >Filters >Add the previous created Selection Filter and Uncheck its Visibility
  • Create a View Template from current View and Name it
  • then from View Template properties check only View Scale and V/G Override Filters
  • apply this View Template made for different scales to the desired Views
Constantin Stroescu
 I made a mistake in my previous post :
 in second row, read Selection Set instead of Section Set..
Constantin Stroescu
JasonKunkel
No way I can think of to do this based on scale exclusively. Closest thing that comes to mind would be to make some View Filters that look for a parameter in the grid and align the filters to scale related View Templates.
Something like
Grids have parameter "See at Scale" set to "Coarse", "Medium", "Fine"
View Template for 1:200 has View Filter that hides any Grid with "Fine" or "Medium" in "See at Scale"
View Template for 1:50 has View Filter that only hides "Fine"
View Template for 1:25 has no View Fitler so you see them all
I usually don't like locking View Template to scale, but sometimes it's useful.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
LinkedIn
spahlevan
Thank you both, for replying so promptly and taking your time!!
I am working in a similar way already. Have created different grid families and using different view templates.
I was just wondering if there is any way to work with the grids base on the "view scales", likewise the Sections which have a parameter called "Hide at scales coarser than".
Thank you, once again 🙂
