Omni Class Numbers in Revit 2017
2 ANTWORTEN 2
Nachricht 1 von 3
1050 Aufrufe, 2 Antworten
I upgraded an R2016 model containing OmniClass data to R2017. For R2016 I followed the process recommended in the Autodesk forum and replaced the taxonomy file appropriately. When I followed the same process for R2017, Revit is not picking up the updated taxonomy as it did for R2016. Please see the attached image. Can anybody help me in resolving this issue?
Srilata Revur
2 ANTWORTEN 2
Nachricht 2 von 3
Sahay_R
als Antwort auf: Anonymous
HI @Anonymous.
Try to relocate the Uniformat Assembly Codes file for the new version.
Manage>>Additional Settings>>Assembly Code
The file is normally at
UniformatClassifications.txt - C:\Program Files\Autodesk\<Revit Version>\Program
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 3
als Antwort auf: Sahay_R
Hi Rina,
Thank you for the response. I tried relocating the text file as suggested but, I received another error. Please see the attached image. Can you help me further?
Srilata
