Offset Dimensions - Newbie
2 ANTWORTEN 2
Nachricht 1 von 3
henrybs14
176 Aufrufe, 2 Antworten
Hi Guys
I've had a good google around/ search forum, Dimension tool, I want to be able to offset my dimensions 800mm apart, but I can't seem to any way to control them. The offset tool doesn't seem to work with dimenions.
Also my text tool doesn't seem to lock onto the dimension tool at all for lining up either.
Any help would be much appreciated.
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
ralphdenhaan
als Antwort auf: henrybs14
Is it this you are looking for? dimensions-in-revit
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 3
RSomppi
As you are placing the dimension after choosing your points, slowly move the dimension, you should see some temporary blue dashed guidelines that the dimension will snap to as you near it.
