Offset compound wall layer to follow roof slope
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
ConstantineC
322 Aufrufe, 4 Antworten
Hello
Is it possible to have the finish layer of a compound wall extend to cover the sides of the roof slope? Can it still be attached to the roof this way?
I have`nt found a way yet.
Thanks!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: ConstantineC
Yes. Add another roof above the roof you have and attach the wall to both roofs.  Then hide the upper roof or move it to another phase.
Nachricht 3 von 5
For future reference, you can also use a Ref. Plane as the target for Attach Top/Base, however in this case, I would  model the roof finished layer(s) as a separate roof as @ToanDN said.
Nachricht 4 von 5
ConstantineC
als Antwort auf: barthbradley
I did try with a ref plane but in my case, the plane would need to be double tilted so the top of the wall is parallel to the face of the roof. If I make a section view perpendicular to the roof plane and then add a ref plane on that view, I think it could do the trick?
Nachricht 5 von 5
ConstantineC
als Antwort auf: ToanDN
Thanks, that seems to be a good way since it is also closer to the actual built structure since you would have a flashing at the intersection edge between roof and wall
