Offset a slotted hole from a reference plane or line in a family
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
coen_vergeer
470 Aufrufe, 2 Antworten
I'm quite new at building families. I would like to offset the slotted hole from a specific line. I am unable to snap the hole correct from the reference line. Is there any way to do this?
it is possible with the round hole, for example, to use the center point of the circle, but not with the slotted hole.
Thanks in advance!
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: coen_vergeer
@coen_vergeer
1. Either use reference lines to the left and right (+ a 3rd EQ in the middle) >>> lock your extrusions to those >>> use offset parameter to the center plane (As per youtube below)
2. model  the slotted hole as a void using face based generic model >>> nest it to the host family
Nachricht 3 von 3
coen_vergeer
als Antwort auf: RDAOU
Great, didn't think of that. Practice makes perfect :leicht_lächelndes_Gesicht:
