offline work
offline work
woodwormbuilders
offline work
woodwormbuilders
Hi I am using Revit LT 2022 new user
2 questions
I leave my revit project open and the computer goes to "sleep" and the internet is turned off. Then when I want to work again on my file hours later, the project is frozen and can't open. I have to force a shut down and reopen.
I also realized that i worked offline and the work i have saved did actually not save and my changes are lost.
Did you save your file to a folder in your local folder?  If so, you open that very file and you should have what you last saved.
And make a habit of save your projects manually before stepping away from.your computer.
woodwormbuilders
Thanks for the answer, I realized I used a file from a drop box folder, so I guess not local.
ennujozlagam
the ideal scenario would be to map the dropbox folder on your c: drive to save your file? thanks
