Odd stirrup shape in revit
10 ANTWORTEN 10
Nachricht 1 von 11
chhuanmawia18
859 Aufrufe, 10 Antworten
When placing the stirrup shape , it gives this odd , cornered and over elongated hook tips (bottom pic). i'm using revit 2021 . I want the hooks to look like the regular one (top pic). Is there any solutionREBAR.jpgREVIT REBAR.PNG
10 ANTWORTEN 10
Nachricht 2 von 11
RobDraw
als Antwort auf: chhuanmawia18
We can't tell much about what you are trying to do from your images or your description. There is nothing building related mentioned or shown. Your best bet is to share the family so we don't have to go by a vague description and guess as to what you are really trying to accomplish,
Rob
Nachricht 3 von 11
chhuanmawia18
als Antwort auf: RobDraw
Hi Rob, I am trying to place a stirrup for a beam and column in my project . However , when loading the stirrup family , the corners are over- circular and almost looks like a circle . The tips are also over elongated . This family is from the revit 2021 library family . I've tried for the standard Indian, English family and all loks the same.
Nachricht 4 von 11
RobDraw
Okay, I see that now. I don't do structure so I didn't recognize what I was seeing without a little context.
Rob
Nachricht 5 von 11
lucdoucet_msdl
@chhuanmawia18
And can you explain why you are asking the Revit Architecture Forum users instead of the Revit Structure Forum?
https://forums.autodesk.com/t5/revit-structure-forum/bd-p/153
-luc
Nachricht 6 von 11
Seems to work fine on my end. 2021.
Let's look at your Propertries first. Post a Screenshot.
Nachricht 7 von 11
chhuanmawia18
als Antwort auf: lucdoucet_msdl
Sorry if it caused any confusion. I had an urgent work and wanted an immediate answer and posted here so i can get the best of both worlds
Nachricht 8 von 11
chhuanmawia18
als Antwort auf: barthbradley
i  tried it on my home system and it worked fine....and i have no idea why!
Nachricht 9 von 11
You don't need to explain yourself. I think we creative types are better at troubleshooting anyways. Definitely prettier than those Structural Forum types.
Nachricht 10 von 11
chhuanmawia18
lol , maybe you're right . I'm good at finding paculiar problems which no one seem to care too much about
Nachricht 11 von 11
chhuanmawia18
If you'd like to know the reason which may be the cause , it might've been due to an incompatibility issue as i started the project in revit 2019 and then imported to 2021 version. Else everything works fine when i just modeled everything in their own version (i think, still not sure though)
