Objects remain highlighted in views after cursor has passed over them when anti-aliasing is turned on
jonathanPFMD9
Observer Observer
Message 1 of 15
jonathanPFMD9
Observer
Observer
First just to say I've been using this forum a lot and appreciate all the guidance, but this is my first post as I haven't been able to find any solutions.  I recently purchased a new laptop and downloaded a trial of Revit LT.  When I turn on anti-aliasing in a view and hover over objects, they remain highlighted from the pre-selection, so that any object I've passed over with the cursor stays blue but is not selected.  This only goes away if I then pan or orbit, and is not an issue if I don't work with the anti-aliaising, but I would like to be able to work in 3D view with this feature.  Any assistance is much appreciated, I've included a screenshot that illustrates the issue, and has a box with laptop specs.  Thanks -
Replies (14)
Message 2 of 15
smeitnier
Community Visitor
Community Visitor
I'm noticing this same issue, at least you've figured out the the root is anti-aliasing causing the problem.  I'd be interested to know why this happens though.
I'm on RVT LT 2022 - 22.0.2.392   -   20210224_1515(x64)
Lenovo Yoga 7 - Intel i5 2.40GHz - Win 11 - 12G Ram
Message 3 of 15
Hello22653
Community Visitor
Community Visitor
I have the same issue. I've had it in both RVT LT 2022 & now 2023. Any news on how to fix this as I like to use the anti-aliasing feature.
Message 4 of 15
jonathanPFMD9
Observer
Observer
Hi - the problem was the processor on my laptop. I bought one with higher
spec and the problem stopped. Hope that helps.
Message 5 of 15
designerjulpiper
Can you  please attach a screenshot of the specs of your laptop? I too bought a new laptop specifically for CAD, it was alot of money, I would love to swap it out for one that is a bit more proficient, I would be grateful! Thank you!
PS  Attached is my 3d view of the anti-ailasing driving me NUTS!
Message 6 of 15
What is wrong with that view?  Sorry I can't tell it clearly from the screenshot.
Message 7 of 15
hv.designbuild
Community Visitor
Community Visitor
Seems like this issue has not been figured out? It sucks I just upgraded my laptop and this is now happening..
Message 8 of 15
nganho
I am dealing with the same problem. And it is driving me crazy.
Message 9 of 15
RobDraw
If it is the same problem as the OP, it was solved by replacing the processor. See message #4.
Rob
Message 10 of 15
wrmarch
HI ... dealing with same problem ... while reading and searching i stubbled on to this ... turn off anti-aliasing
go the the cube ... visual style ... open and click on graphic display options ... turn off anti-aliasing and poof
Message 11 of 15
omar_abdullahE7X2P
Observer
Observer
try to disable anti-aliasing option, it solve the problem for me.
Message 12 of 15
ACastroE64PM
Observer
Observer
This did it for me on a slightly basic PC.
Message 13 of 15
CCasilagCUHYS
Community Visitor
Community Visitor
I have the same problem and thanks, this works for me.
Message 14 of 15
BBQMangoes
Community Visitor
Community Visitor
I am experiencing the same problem. Turning off anti-aliasing fixed it though. Thanks for the solution!
Message 15 of 15
GRZEGORZ_PLECHAWSKI
Same issue with surface pro 8 when antialiasing is ON. Any help with this?
