Objects reflecting other objects color when rendered
3 ANTWORTEN 3
Nachricht 1 von 4
479 Aufrufe, 3 Antworten
I am rendering an image that has an orange carpet. The ceiling is a suspended ceiling white. When I render the orange carpet is reflecting really strong on the ceiling make it orange as well.... I have tried adjusting the material as carpet and so on but no luck.
Any tips?
3 ANTWORTEN 3
Nachricht 2 von 4
Lakshman01
als Antwort auf: Anonymous
Hai @Anonymous Please check your graphics performance configuration ( check with Turn ON / OFF once !! ) or Could you please attach the file ? or any references ? Thanks Lakshman
Nachricht 3 von 4
als Antwort auf: Lakshman01
Hi Laksham,
Thank you for your reply.
I have attached a photo for you. The carpet should be orange not yellow but that is not the main problem. As you see the ceiling and the lights has an yellow reflection to it. This render is made on high finish at 300 DPI.
I hope that can give you an idea. M.
Nachricht 4 von 4
nigel.robertson
I am experiencing exactly the same thing in a warehouse i am doing, that has a green epoxy floor (yes in real life :)) - and it is turning the whole room green when i render it.....
