objects outside of view range still visible
27 ANTWORTEN 27
GELÖST
Nachricht 1 von 28
kgatzke
11280 Aufrufe, 27 Antworten
Can someone explain why ANYTHING outside of a given plan view range is visible AT ALL?  I'm on a third floor plan view and walls with bases ABOVE my primary range are visible as though cut in section.  The best reason we can figure out why is because their bases are set relative to the 1st floor working plane, but even if that's the case what sense does it make to have a view range if things outside it can still be visible?
27 ANTWORTEN 27
Nachricht 2 von 28
als Antwort auf: kgatzke
Underlay?
Nachricht 3 von 28
kgatzke
als Antwort auf: barthbradley
@barthbradley
No, and I've tried every setting of depth clipping, coarseness & visual style.  I'm in a working view with no template settings.  I squeezed the view range down to a 1/4" and I can still see everything.
Nachricht 4 von 28
What is the Category of Element(s) that you are seeing?  Window, Casework, and Generic Model behave differently with respect to the View Range.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Nachricht 5 von 28
kgatzke
image.pngWell, pretty much anything hosted to this level or a level below it.  But not the roof above.
Nachricht 6 von 28
Huh? Can you replicate? In other words, create a new 3rd Floor Plan View with same results?
Nachricht 7 von 28
A total of 1/4"? That is some weird view range.
Nachricht 8 von 28
kgatzke
@barthbradley
I created a new 3rd floor plan from scratch and it's view range behaves as it should.  Something is cracked about the view range on that other view.  Don't know how it got that way but it's gone now.
@ToanDN
I was just squeezing the view range into a thin slice trying to force out objects 30 ft below it as a test.  Didn't work.
Nachricht 9 von 28
phanideepak
Hi, @barthbradley
The same problem I have been facing right now, I have gave the Cut plane and Cut with Line option , even though the result is I can view all the unnecessary Elements out of view range .
The required plan is at +4.900m and as per that I have arranged my view range as shown below but still can see the elements out of the Range .
Hoping for solution.
Phani Deepak Uppala
Required level ++4.900 but Still can see +4.400 Elements and below thatRequired level ++4.900 but Still can see +4.400 Elements and below thatView Range SettingsView Range Settings
Nachricht 10 von 28
phanideepak
als Antwort auf: phanideepak
Hi @MostafaElashmawy  can you please advise me on the above query.
Nachricht 11 von 28
MostafaElashmawy
Try the following.
In the view properties,  under crop view, there is anotation crop, activate it and reduce its extent as possible.
Mostafa Elashmawy
Nachricht 12 von 28
phanideepak
als Antwort auf: MostafaElashmawy
Hi @MostafaElashmawy ,
Annotation Crop just reminds us for the Annotations which are place outside the range , Well I have tried using Annotation Crop and still its the same with the view.
As per the view range It should be visible only for the Plan @ +4.900 , But still I face to see +4.400 level Slab and +3.900 Slab which are irrelavant to view range as shown in the image.
Hoping for Solution.
Phani Deepak Uppala
Nachricht 13 von 28
MostafaElashmawy
Sorry couldn't read your first post properly.
Can you share the model.
Mostafa Elashmawy
Nachricht 14 von 28
MostafaElashmawy
So did you try checking if there is no underlay.
from properties of the view>> underlay>> select none.
Mostafa Elashmawy
Nachricht 15 von 28
Also is your slab made used floor tool or is it a model in place object or a family.
Mostafa Elashmawy
Nachricht 16 von 28
phanideepak
There is no underlay assigned to the view and its not model in place.
Nachricht 17 von 28
Floors within 1200 mm under the view depth will show, that is why your 4400 and 3900 floors show in plan at 4900. Change the view depth to 5650 and the floors will disappear.
Nachricht 18 von 28
phanideepak
als Antwort auf: ToanDN
View Depth / Bottom Clip Plane cannot be set above the cut Plane and it doesn't satisfy the View Range.
Nachricht 19 von 28
Then hide the floors.
Nachricht 20 von 28
Bnilath
If we need to hide everything manually what is the purpose of view range ?!!
