I'm trying to import a CAD file in Revit but some objects are not visible.
The object are visible in the preview box (see below) but are not once placed in Revit.
All layers are visible in the Visibility/Graphics for the imported file (see below).
I've tried exploding, purging, and placing the objects on multiple layers prior to importing but they are still not visible.
Please advise.
Upload (relevant part of) your cad file, then we can have a look.
Which Autocad and which Revit version are you using?
Louis
Please mention Revit version, especially when uploading Revit files.
@Anonymous wrote:I'm trying to import a CAD file in Revit
This could be the problem. Importing into CAD into Revit is not always a good practice. Not all objects can be imported. What are the objects that are not importing.
Those drawings are not drawn 1:1. One of the limitations of importing is that Revit won't do anything less than 1/32".
Scale up the drawing to see if that helps.
run a recover on the file in Autocad, then try linking it into Revit. when i did that it worked (it had 2 errors in the file)
Howard Munsell
