Objects not rotating/changing when changing the rotation angle value
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
dick.elsman_infranea
462 Aufrufe, 1 Antwort
Hi all,
I have a problem when changing my angle values of the objects of degrees.
My elements are placed along a path and  to match the elements, the profile can rotate. for a lot of these objects, this solution works perfectly, but for some, it does not seem to work, when the value exceeds about 2 decimals if the value is below 0.1
Below the problem:
original object:
object with changed value
Somehow the profiles do not rotate when changing these values, even when i change it to "-0.04"
It also fails to work in the family editor
Can anyone tell me what the cause of this problem is and/or suggest a solution?
Working with revit 2020.2.
Thanks in advance!
1 ANTWORT 1
Nachricht 2 von 2
I got a reply from Autodesk that the software is limited to rotations up to 0.1 degrees
untill they resolve that, this will remain unanswered.
