When I print from Revit to PDF some of my equipment objects are missing, see attached images. I adjusted the exhaust hoods visibility to show them as halftone so the equipment underneath is visible, which shows up while in any view in Revit. I've tried printing using Raster Processing, but I still have the same problem. In the PDF printer I also tried selecting "Replace halftone with thin lines".
I tried adjusting the visibility of the exhaust hoods which are generic Revit families, but haven't found a solution.
Thanks in advance for any assistance!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Thanks for offering a solution!
Possible, I'm not sure what warrants a custom viewport, I adjusted to show only my equipment layout. I believe barthbradley's solution has solved this issue.
Well that definitely worked, thank you! I find it very odd, that I did try this prior to posting and did not receive the same results. Maybe shutting everything down and restarting helped.
