Objects from referenced Revit file displace / disappear after binding
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
a_paynter
168 Aufrufe, 1 Antwort
Hi there,
encountering a very strange problem with a referenced Revit file that we are trying to bind into our main model.
Received a Model from our structurally engineer, referenced it into our model, all positioned perfectly, no problems there. As soon as we bind the file, a large portion of the objects from their file then fly off and move about into strange locations, often quite far away.
Any ideas here?
It's worth pointing out that when i reference their model into a fresh empty Revit file and then bind it, everything stays exactly where it should be.
1 ANTWORT 1
Nachricht 2 von 2
a_paynter
als Antwort auf: a_paynter
Solution Found, detached a file from central model, cleaned it with audit and purge.
Referenced file then binded perfectly and without issue.
