Hi all,
Hopefully someone can assist.
I have a title block family set up and loaded into my main template file. I have the linework forming the title block set as a subcategory in the object styles. The subcategory is called W BORDER. This subcategory is set to display at line weight 3.
When I load the template, the title block family is present and correct, but the W BORDER linework is all displaying as line weight 1, so much too thin.
If I double click the title block family, and go into the family editor, the W BORDER linework displays correctly at width 3 and object style subcategory is correct in the family editor.
I've checked object styles > Annotation Objects in the main template file and the subcategory W BORDER is claiming to be line weight 3 as it should be, but its not displaying at 3, its displaying at 1.
I don't have thin lines on either! It also doesn't plot correctly. What am I missing? An overrride somewhere?
Correct lineweights displaying in the family editor
Subcategory object style in the family editor
Incorrect lineweights displaying in the template
Yet correct object style setting in the object styles in the main template
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Ah! That's fixed it, thank you very much.
Physical width of lineweight 3 in the family editor was 0.7mm, but in the main template it was set to 0.25mm.
Change it to 0.7mm to match and it all displays as intended. Lovely job, many thanks
