Object Styles Line Weight can be set only by integers.why?
Shay.Gaghe
Shay.Gaghe
hi
im new to Revit,
in Autocad we used to define the line weight to values like 0.6,0.7
in Revit Object Styles eqivalent, i tried to apply values like those,
but Revit always round it off to the closest integer, why is that?
Shay Gaghe
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
See Manage Tab=>Additional Settings=>Line Weights.
@Shay.Gaghe: did my post point you in the right direction? If so, I'm in need of solution credits. Baby needs a new pair of shoes. Smiley Sad
