Object reference not set to an instance of an object Revit
maciej_kraj
maciej_kraj
Hi All,
We are working on an interiors project and using Enscape for rendering.
Whenever we try to create a view for Enscape it comes up with an error see attached image.
We have upgraded the project from 2018 to 2019 and the issues seemed to have gone away temporarily, but its just come back again.
Any thoughts?
sash.kazeminejad
I would reach out to Enscape around this issue to see if they have any ideas.
One other thing that may help you. Close out of Revit, go to the journal files folder and clean out all the journal files. Then relaunch Revit and re-create the error. Once it is created, go back to the journals folder and open the journal file that was created. See if you can find the error in the journal. Look at some of the text before the error to see if there are any indicators as to what the issue may be.
Also, check and see if you GPU driver is up to date. This could be the cause.
Sash
