Object Properties in exported revit file using Naviswork
0 ANTWORTEN 0
Nachricht 1 von 1
tonynkyc
87 Aufrufe, 0 Antworten
This NWC I got as the results from exporting revit to DWF (method 1), how to get that "material" field? And the "name" field is the "Family Name", while the "type" field is not the "Family Type Name", how can I get the Family Type Name?
While if I used Naviswork Exporter (method 2), the "name" field is from "Family Type Name", not "family name"
Both of them don't have material field filled.
Actually my naviswork view should have:
1. The whole building should be divided by each floor
2. Should have texture exported (method 1 cannot export texture, only color)
3. The object at least must have family name parameter, type name parameter, and material parameter for finishing object (wall, flooring)
What is usually the best practice to export Revit to naviswork in large building (I think it's not even a large building, the architectural file is under 400MB)?
Thanks in advance
0 ANTWORTEN 0
