Object dimensioning woes
1 ANTWORT 1
Nachricht 1 von 2
shawnrgoodell
173 Aufrufe, 1 Antwort
I am new to Revit after using Autocad, Rhino, etc for years.  When I create a wall or draw boundary lines for a floor, no matter what dimension I enter, revit enters it as 1 1/2" smaller.  This happens even if it is the first object drawn and there are no other object it is constrained to.  If I enter 50' 3-3/4" revit will change it to 50' 2-1/4".  I is happening over and over again regardless of the actual number entered.  I have searched online and in forums for an explanation but I cannot figure it out.
Thanks in advance for answers!
1 ANTWORT 1
Nachricht 2 von 2
Alan.johnson1970
als Antwort auf: shawnrgoodell
You could check to see if there is any rounding increments applied.
Manage Tab> Settings Panel> Project Units
AJ.
