NWC export problem
NWC export problem
NWC export problem
Hi to all,
I have a problem with the NWC export from Revit:
I have a Curtain Panel family in which are nested 3 Generic model families. When I open the NWC file with Navisworks, some panels (totally random mode) take a different type of the nested families distorting the original geometry.
How it's possible? How can I manage this issue?
Matteo Sarrocco
http://bimnote.blogspot.it/
sureshchotrani
In file reader for option editor, kindly select linked file. It doesn't make sense but may help.
Other way export via dwf from Revit and then directly open in Navisworks.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
