NWC export of a linked model
3 ANTWORTEN 3
Nachricht 1 von 4
nikhil.patel2
256 Aufrufe, 3 Antworten
I successfully exported an nwc of a linked model from a Revit view/scene. The problem is when I append in my Navisworks, the model is not "itemized", it's one block essentially. This means I cannot select an object to see it's properties. I know the data is there as I can search for properties if I know what I'm looking for. But really I want to be able see the properties.
Will repost in Navisworks forum if there's additional processing that needs to be done there.
Much Appreciated.
3 ANTWORTEN 3
Nachricht 2 von 4
Yien_Chao
als Antwort auf: nikhil.patel2
what kind of export settings did you use? 2x3?
Nachricht 3 von 4
Nachricht 4 von 4
nikhil.patel2
als Antwort auf: ToanDN
Yep, stumbled through that one already! When I export Convert files checked, I append into a Navisworks file set (nwf). Then when I go to select an item, the whole model is selected (can't select an item individually). I am however able to Find Items if I know what I'm looking for. Using the Selection Inspector, I can then select the item and see the properties. I just can't select an item directly. Could this just be a limitation when exporting linked models out of Revit in this manner?
The use-case here is on a large project, we can't directly open another trade's model. So it's useful to live-link, have view ready for export an nwc for investigation.
