Hi All,
While I am exporting to NWC from Revit I am getting the following error. Its only happening for one specific file other files are fine. can anyone get the same error please let m know if we have any solution for this.
Hard to troubleshoot based on that screenshot. Is it a show-stopper? In other words, does it prevent the rest of the model from exporting?
@Farhan_Peer wrote:No its happening for only one file
My question was: does the rest of that "one file" export okay?
Yes, Even i did all the following but its not working.
I did all the above points but still i am getting the same error only for that file others are fine.
I Found the solution for this you can remove all the 3d views and recreate the view again then if you try to export to NWC its working.
