Hi when import nurbs object in revit he read in nurbs or convert the object in polygonal?
Comparing the model Made in rhino, and then imported into revit, the revit models seems less clean and linear, more serrated.
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
Take a look here:
https://www.lynda.com/Revit-tutorials/SATRhino-import/578063/604774-4.html
http://www.bimtopia.com/index.php/item/transferring-models-rhino-to-revit-to-rhino
https://wiki.mcneel.com/rhino/architecture/bim/rhino-to-revit
It should be noted that Rhino, 3dsMax, Maya, and other 3d programs handle complex/compound curves differently than Revit. Using Revit's Conceptual Massing Tools will help you to be able to generate Revit elements such as roofs, walls, floors, curtain systems, etc.--from imported models created in these other apps.
Hi @Anonymous
Here is a handout that explians exporting Rhino And Sketchup Models Into Revit Associative Content.
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
