Hello, have a problem with floortag.
I deleted samo tag room but think remained in program memory.
When put a new numbers (1, 2 3) say me are a duplicate number.
How can I do to delete this problem?
Thank's very much
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Gelöst von Kimtaurus. Gehe zur Lösung
Look at the Families in the Project Browser. Under Annotations, delete the tag and then reload it.
When you're editing the rooms (deleting-creating), know that when you delete a room from the model, it remains in the project.
The room is removed from its location in the building model. However, the project still contains the information about the room.
In a room schedule, the room is listed as Not Placed.
You'll need to delete these rooms in the schedule (or change their numbers), if you want new rooms using those numbers.
What exactly are you trying to tag? I'm not following what you'r etrying to do "Otherwise if have more tag put yet on project with replace have to reput all of teh tags in this way"
Do you want to replace the existing tags, change the parameters?
@Sahay_R say me to delete and replace the tag.
If I replace the tag after have to re-tag all the rooms. If have a lot of rooms is a problem.
There's not possibility to resolve the problem without replace the tag?
What @Sahay_R say to me is in the second .rvt.
But the tag type are different.
How can have the same kind of tag in project (with volume and area) as in the first .rvt?
Thank's very much
You can replace the tags by loading the new family in the project.
Next select the old tag in a view, or go to the type in the family browser, right-click select all in project.
In the properties you'll see the number of selected tags.
Next then choose a new type from the drop down type selector.
Furthermore the error of duplicate number tag remain.
The number you're assigned is NOT related to the tag. It's a ROOM parameter.
The fact that you're getting this message, means there's already a room in the project with that number.
Create a Room Schedule and sort by number to see the number which are already in use.
Next then choose a new type from the drop down type selector."
please can you do me a scrrenshot of proceedings to undrestand?
"The fact that you're getting this message, means there's already a room in the project with that number."
How can detect the number in project? do not find.
Thank's very much
Here there's the dubble tag.
Do not find the first numeration room "locale 7 - numero 7 - 207268"
Create a Room Schedule. It will show you things like duplicate or unplaced rooms. Delete them when you see that. That should take care of the error message.
Do you have a clean copy of the tag saved in your library or project folder? The first thing that I would do would be to check on that, and then reload the clean copy of the tag family into your project.
If not, you can always go into the tag family and add new labels that will give you Area and Volume.
"If not, you can always go into the tag family and add new labels that will give you Area and Volume."
I haven't a clean copy.
Sorry, when go in Tag family can I import other label?
Of tag room there's only 1 and as in screenshot in preview there's area but when overwrite not.
Sorry a lot
In the Tag family, click on Create>>Label.
You will need to click to place the Label - then the Edit Label box comes up. You should see the Area and Volume parameters on the left side of the box - you will need to select the parameter and click the green arrow to move it to the right side of the box.
