Numbering sequence in Schedule
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
achusetiawan
4158 Aufrufe, 8 Antworten
I currently have a problem with numbering on the schedule. Because I'm currently making a manual, so when I add a line or delete a line, I have to retype it. Does anyone have the same problem and the solution Thanks.I currently have a problem with numbering on the schedule. Because I'm currently making a manual, so when I add a line or delete a line, I have to retype it. Does anyone have the same problem and the solution Thanks.I currently have a problem with numbering on the schedule.
Thanks.
Tags (2)
8 ANTWORTEN 8
Nachricht 2 von 9
ennujozlagam
als Antwort auf: achusetiawan
you can refer to autodesk apps store .and see if helps
Nachricht 3 von 9
Need some more information to troubleshoot.  Like to see the Schedule setup. Can you post it?
Nachricht 4 von 9
achusetiawan
als Antwort auf: ennujozlagam
I will try with this application, if indeed there is no credit from revitnya,
Thank you for helping
Nachricht 5 von 9
Khadourwaseem
I've actually found a way online, You can check it right here
https://www.youtube.com/watch?v=H1Z3f1pgyPE
Nachricht 6 von 9
batbilegbt1
als Antwort auf: Khadourwaseem
is there any solution here?
Nachricht 7 von 9
als Antwort auf: batbilegbt1
Solution to what problem?
Nachricht 8 von 9
batbilegbt1
als Antwort auf: ToanDN
i manually number the parts highlighted in red, it takes a lot of time so maybe is there any tool to automatically number this section?
Nachricht 9 von 9
PyRevit renumbering tool.
