i have an elevation view drag already to sheet title block but the number or letter don't show up on plan, any reason. any helps is much appreciated. thank you
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Look at the stock elevation mark and see how it is done.
the two views are on the same sheet but still cannot see?
Look at the stock elevation mark and see how it is done. - i dont understand this?
Two views? That elevation mark indicates there are 4 views. Share your file here.
in the 1 sheet title block (plan) there are 4 views but only 2 views drag to the sheet, the 2 views are on other sheet.
sorry i can't share the file, i signed the FDA. thank you for your help.
Again, you cannot use this Elevation mark for more than one view. Place separate marks.
