Note tag
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
sbspiegel
459 Aufrufe, 8 Antworten
Note tag
What would be the best way to change this multileader tag to a spline instead of a line? Is there a way to create the the spline with 2 adjustable points?
8 ANTWORTEN 8
Nachricht 2 von 9
sbspiegel
als Antwort auf: sbspiegel
Ive attached a picture here
Nachricht 3 von 9
You can't.
Nachricht 4 von 9
sbspiegel
als Antwort auf: barthbradley
Is there anyway to create the multileader spline separate without the text?
Nachricht 5 von 9
vitorbortoncello
Revit's annotation tools are primarily designed for precision and control. However, you can achieve a similar effect by using a Detail Line, but personally i don't think it is very helpful to do so
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 6 von 9
Are you looking for a workaround or a standard?  In other words, are you wanting to do this selectively and limitedly, or everywhere and all-the-time?   I mean, you can turn off Leader Lines and draw Splines in their place, but this isn't a practice I'd standardize.
Nachricht 7 von 9
sbspiegel
How do you turn off just the leader lines?
Nachricht 8 von 9
sbspiegel
How do you turn of just the leader lines?
Nachricht 9 von 9
