Hi, is there a way not to see the outline of the floors on the walls in a 3d view? (see image) Thanks
The floor should setback behind the wall finish layer. Draw the wall is the as one tall wall spans from base to roof. If there is a wall at each level, then join them so the finish appear continuous.
I tested with a setback of 1" from the edge of the slab to the finish surface and I can replicate the "ghosting" effect on Hidden/Shade/Consistent Color/Realistic visual style if I zoom out far enough. Toggling hardware acceleration doesn't fix it.
Perhaps this is the case where Certified video cards showing their value (if anyone can confirm). I have a GeForce 1060 GTX 6GB which is not certified.
I've got certified Quadros, and it does the same thing. They don't print though.
@chrisplyler Thanks for the confirmation. Now I know what to NOT spend money on (looking at you Quadros :).
