Not showing Mass model in 3D View
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
lygking
8131 Aufrufe, 8 Antworten
Dear All,
I tried to link mass model into project.
But, model is not showing in 3D view. (Can see the model in plan view and section view)
I turned on mass type in VG setting. 'Workset', 'Revit Links' and 'Imported Categories' also.
I can't understand this problem.
Please let me know what I missing.
Thanks and Regards,
8 ANTWORTEN 8
Nachricht 2 von 9
ennujozlagam
als Antwort auf: lygking
@lygking hello, you can try go to massing & site > show mass by setting. please see attached. thanks
Nachricht 3 von 9
lygking
als Antwort auf: ennujozlagam
 @ennujozlagam Thanks to your fast reply :leicht_lächelndes_Gesicht:
But I still cannot see the model.
Nachricht 4 von 9
ennujozlagam
@lygking try to check <<click HERE>.
<<click HERE>>. thanks
Nachricht 5 von 9
ennujozlagam
@lygking reason cannot see <<click HERE>>. thanks
Nachricht 6 von 9
ennujozlagam
@lygkingi tried to replicate what you did and it's works fine with me, vhave tried to click show mass form and floors. thanks
or check your phasing
Nachricht 7 von 9
@lygking
- If the 3D view is cropped, then uncheck Crop region
- Uncheck Section box
- Verify Phasing (change the Phase to the latest and Phase filter to Show All)
By the way, did you create the mass in a different RVT file and link it in?  Why didn't you create the mass using the Conceptual Mass family template and load it in your project?
Nachricht 8 von 9
kday86Y9FB
Thank you!
Nachricht 9 von 9
seijord1
You could check the family category of the mass - when you go to "edit mass", you can change the family category of the mass the same way you would change the category of a normal family:
The category of your mass might be "Generic Models", or other category which might be turned off in your 3D view.
