I keep getting a 'not responding message' every other click and takes forever to clear up. This was not doing this two weeks ago. My file size is 15.5MB. I already did a clean install.
Specs:
Radeon Pro 460
16gb Ram
Followed the instructions here: https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2017/...
To no avail. The circle loading still shows when zooming in moving around changing views, etc.
Not that I can tell. No messages from the audit, and no warnings in the ribbon. It's a massing model. Project was working fine a couple weeks ago, not sure what changed.
You have no warnings?! Good for you.
Hard to know for sure without examining file. Post it here. We'll take a look at it.
Going to post my site model as well as the linked revit file that needs to into it.
Site Model: "New york site"
Linked Revit Model/Massing: "massing"
I have added the file to "attachments" if it isn't working, what would be another way to upload it? I found it would not let me attach two files here is a google drive
https://drive.google.com/drive/folders/18aQpVKKvvGjkwYhd13x4_4cSD6BnWSge?usp=sharing
I got them both and open the Massing.rvt, and it nearly crashed on me twice. I can't risk crashing right now. I'll check it out later if someone else doesn't come through in the mean time. You may also want to open a support case through your Autodesk Account in the mean time. They usually respond in a couple of days.
