If I am in the respective 3d view I can see the entire image, but when rendered gets all dark
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
@Anonymous wrote:If I am in the respective 3d view I can see the entire image, but when rendered gets all dark
… hi @Anonymous
… there are three possible causes for this:
…. 1- Your camera is inside a wall or some element - you need to go to your floor plan view and check that out….. if so, just move it forward a couple of inches
…… 2- your exposure is in "the dark side" – go to your rendering settings and adjust the exposure control
….. 3- you are in an enclosed space with no artificial lights and no sun coming in…
…. Could you upload your .rvt file to take a look?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Right on point . just checked those and two were as you said.
***** I can't upload the project (internal company restrictions)
