Not being able to cut Sphere.
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1834 Aufrufe, 4 Antworten
I'm trying to cut an an object that has been Revolved into a hollow sphere. I'm drawing the void form to cut the sphere, but it is not letting me.
Please see the attached screenshots for help.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Are you by chance try to cut the OOTB Mass Sphere?  If so, it has a family instance  parameter to control how many the degrees the revolve is.  180 degrees would "cut" it in half.  No void cut needed.
But, you should be able to cut it with a void in the family.
BTW: If it isn't the OOTB Mass Sphere, but it is a Revolve -- use the parameter I spoke about. That is, associate the "Start Angle" and/or "End Angle" to a Family Parameter that you can change in the Project as needed.
Nachricht 3 von 5
Corsten.Au
Hello
use cut geometry..
I have created one screencast as well..
https://autode.sk/2Se2jib
Cut Geometry 1. Pick 3d ( sphere ), then pick Void (Cut Geometry )...Cut Geometry 1. Pick 3d ( sphere ), then pick Void (Cut Geometry )...
Corsten
Building Designer
Nachricht 4 von 5
Draw the void and the solid within the same In place family.
Nachricht 5 von 5
delineantebim
als Antwort auf: barthbradley
Thank you so much for your advice
