Not able to unpin mullion from Store front windows
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
904 Aufrufe, 3 Antworten
I am trying to place a door into my  storefront window wall.   I am only able to highlight the entire storefront window glass but its not allowing me to unpin or delete the mullion.  Is there a setting that needs to be adjusted or maybe I am doing something wrong.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Sounds  like you my have unchecked "Select Pinned Elements" .  Look under "Modify" or at bottom right of screen.
Nachricht 3 von 4
Do you mean you are not able to TAB select mullions to unpin them?
Nachricht 4 von 4
Is it a group by chance?  Usually once a curtain wall is a set size for a window assembly it is grouped so it can be placed multiple times in the model.
