Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
yes I Tried but no result, I am not even able to tab select the generic model which is nested in to the curtain panel it is only selecting entire curtain panel.
When I make shareable, that generic model is not showing in assembly while extracting fabrication drawings.
Thank-you, tab selecting helped and I have one more doubt. I want to give fabrication drawing for shareable parts also in the same panel assembly so that all the panel part fabrication in one set. Is it possible to do that or we have to create assembly for each and every part of the panel. If 2nd option is the only possible thing, then can we make selected sheets in one set so that all the drawing sheets belonging to the panel and its parts are kept in one place. This would be very helpful as I have more than 20 types of panels.
