Hey All,
I'm trying to select objects with my cursor. However, I am not able to select elements individually. I have attached the screenshot. It would be great if anyone could help.
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
It is not clear what you are doing or what you are trying to select....
See possible options below:
It's not evident what kind of manipulation you are doing. Is it a linked file that you're working with?
Try pointing your mouse to the element you wish to select and use the "TAB" key on your keyboard to cycle through the selection options until your desired element is highlighted. You then click to select.
it looks like the file you are trying to select is a linked file? if yes try to to VG and follow the steps below and see if helps. thanks
