Not able to link DWF file in Revit
2 ANTWORTEN 2
Nachricht 1 von 3
accounts
399 Aufrufe, 2 Antworten
I am trying to link a 2008 DWF file into Revit 2019 with no luck. When I initially try to load the file it says 'Some sheets have no markups and will not be loaded' When I look in the 'manage links' section there are no links at all. Is it possible to use a 2008 DWF in Revit 2019?
Tags (4)
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: accounts
hello, can you try to install hot fixes for design review and see if helps. thanks
Nachricht 3 von 3
Was the DWF created from the same Revit file (or the file before upgraded to 2019)?
