Not able to delete this element from my project
7 ANTWORTEN 7
Nachricht 1 von 8
1670 Aufrufe, 7 Antworten
I downloaded this element and pasted it in my project and i am not able to delete it, i have posted a screen shot of it.
Please help me out, Thank you!
7 ANTWORTEN 7
Nachricht 2 von 8
Redrunner92
als Antwort auf: Anonymous
It looks like a curtain panel element. Try using your tab key to select the curtain wall element rather than the panel element, then delete the dashed curtain wall element.
You can't delete individual curtain panels, these are controlled by their host curtain walls. That's why you can't directly delete that item.
Nachricht 3 von 8
als Antwort auf: Redrunner92
Yes, it is a curtain wall element, i tried what you've said, it doesn't get deleted.
Thank you for replying.
Nachricht 4 von 8
Delete the host Curtain Wall. Should be there. Try a extra large selection window.
...maybe one of these restrictions are preventing you from selecting it?
Nachricht 5 von 8
Redrunner92
Are you able to change it's type to, say, an empty panel? Just asking to see what Revit is allowing you to do with it. Make sure the dashed lines are selected, not the panel itself. And as @barthbradley said, enable all selection tools and use a large window from right side to left side. Let us know what you can and can't do with it if this doesn't work.
Nachricht 6 von 8
VitorBIM
Have you tried to Unpin the element?
Nachricht 7 von 8
mserranoUA5ZH
Change the type and name of the element and delete it from the project browser
Nachricht 8 von 8
malcolm_stroud
I found the delete button on the keyboard sometimes wouldn't work, but select > right click > context menu > delete from menu did.
