Not able to change glass panel material
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
varia024
959 Aufrufe, 5 Antworten
Im trying to change the render appeareance of  a curtain wall of glass in my project and it seems blocked the option for material and finishes and i dont find any other option to change it.
Please help
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: varia024
Edit the Curtain Wall Panel itself.
Nachricht 3 von 6
Edit Curtain Panel > System Panel: Glazed type and change the material.
Nachricht 4 von 6
Actually, you may not even need to edit the Panel's Material. You might get to where you want to go by just editing the "Glass" Material's Appearance settings.  Those setting are the ones used for Realistic and Rendered Views.
Nachricht 5 von 6
varia024
als Antwort auf: ToanDN
Yeah, that was not working. : (
Nachricht 6 von 6
varia024
als Antwort auf: barthbradley
With that I was able to do it, Thank You.
