not able to browse projects templetes and not able to create levels
1 ANTWORT 1
Nachricht 1 von 2
189 Aufrufe, 1 Antwort
not able to start the drawing... previously i was working with 2018 it was then working properly but after uninstalling the software and then installing the 2017 version it is not working properly....
1 ANTWORT 1
Nachricht 2 von 2
Sahay_R
als Antwort auf: Anonymous
It appears that your computer is not mapped to access the Revit 2017 templates
R>>Options>>File locations
You can set up the location to project template files here. Revit project files are located here
C:\ProgramData\Autodesk\RVT 2017\Templates\US Imperial\xxxx.rte
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
