None of the print options open on Revit 2017 student version
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
606 Aufrufe, 1 Antwort
Hi, so I'm trying to print one of my files to PDF and when I go into the print page I'm able to select "PDF" as my print option but most of the other functions, such as opening up browse to select the file location, clicking setup to change file size etc or select to tell it which sheets or views I wanted included in the file don't pop up. Has anyone had this problem or know how to fix it?
1 ANTWORT 1
Nachricht 2 von 2
Jacob.westergaard
als Antwort auf: Anonymous
Hi Faraz,
Thank you for taking your time to post this on the forum,
This does sound like the Microsoft Update issue that has been going on for some time now.
Could you try and go through the steps below.
A) Installing
If that doesn't solve it for you, until we find a solution you can use this workaround:
B) Accessing Print dialog from R > Print
  1. Access the print setup directly through the R ribbon under print
  2. Set the settings
  3. Quit the dialog
  4. Open the Print dialog and click Print
Let me know if you have any question or if you need help in any way, I look forward to hearing about your progress,
Best Regards,
Jacob Westergaard
Autodesk Product Support Team
Revit/CAD Specialist
Jacob Westergaard
Autodesk Premium Support Team
AEC Premium Support Services
