None of the created elements are visible in Floor Plan: Level 2 View.
2 ANTWORTEN 2
Nachricht 1 von 3
1088 Aufrufe, 2 Antworten
When I am working on the second floor of my drawing I put down walls and doors, I can see the walls on Floor Plan: level one but when I put doors I get the error message "None of the created elements are visible in Floor Plan: Level 2 View." the doors do get inserted though, I can see them in 3D mode and weirdly enough I see them in Structural Plans: level 3. This is weird because it is in the level 3 structural plans but I don't understand why I cant see them in level 2 floor plans. Please help!!!!
2 ANTWORTEN 2
Nachricht 2 von 3
cbcarch
als Antwort auf: Anonymous
Check:
-Phasing
-Worksets
-Filters/VG of 2nd floor view
-Design Options(if any)
-View Range of 2nd floor plan
-View Template(s)
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 3
Sahay_R
Go to a 3D view. Click on each of the created elements to ensure that they are on the correct workset, phase, etc as @cbcarch so correctly  points out.
Also - check to see if the view is controlled by a View template and make sure that the categories and worksets that the objects are placed on have been checked.
Finally - go to the offending view - at the bottom of the Properties palette, make sure that the View is set to the correct phase.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
