(none) In Schedule
5 ANTWORTEN 5
Nachricht 1 von 6
PhilvK
365 Aufrufe, 5 Antworten
(none) In Schedule
I'm pretty sure this has to do with the fields or lack of fields in my key schedule, but how do I correct the fields in my door schedule so that my columns don't show '(none)' ?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: PhilvK
You will always have a (none) in the dropdow list created by a key schedule.  That is for you to release the selected element from using any key and subsequent preset information entered in the key schedule for that key.  I think it is useful.
If you already assigned a key to every scheduled elements then you should not see any (none) in the element schedules.
Never mind the below.  I didn't realized it was a 'key' schedule.
You can change how the field display in Format tab.
Nachricht 3 von 6
PhilvK
als Antwort auf: ToanDN
I just recreated the Key Schedule. The fields weren't matching up.
Nachricht 4 von 6
PhilvK
Running into this problem again. I have a column in a door schedule that is showing (none) for all fields but am not tying the schedule to a key schedule. How do I 'release' it?
Nachricht 5 von 6
PhilvK
Nevermind. I think it is pulling from a key schedule....!
Nachricht 6 von 6
Mike.FORM
Just remove the key schedule parameter field from the schedule.
