no walls for roof plan
19 ANTWORTEN 19
GELÖST
Nachricht 1 von 20
joyquilt1021
3141 Aufrufe, 19 Antworten
I am new to REVIT, very experienced in Autocad.  I have spent 3 hours trying to view any walls on a roof plan. I have read the posts, I have set the view template to none so I could vary the view range, tried every variation.  There is nothing to view on the roof layer but one line that reads 'import symbol.'  Any new ideas would be appreciated.
19 ANTWORTEN 19
Nachricht 2 von 20
als Antwort auf: joyquilt1021
What variations?  Try bottom of view range  = Unlimited?
Cut a section to understand your wall heights related to levels.
Nachricht 3 von 20
Depends on how you created the "Roof Plan" also.  What is the Associated Level?
...since you are new to Revit, I'll throw in this bonus:
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
Keep it handy for reference.
Nachricht 4 von 20
joyquilt1021
als Antwort auf: ToanDN
What variation is confusing to me. Revit lt 2022?
I have tried the bottom of range among other options in those hours of
effort. Many different combos were unsuccessful.
I have section cuts which show walls going from floor to lower roof line.
Thank you for trying!
Nachricht 5 von 20
post your project here.
Nachricht 6 von 20
joyquilt1021
als Antwort auf: barthbradley
Please explain how to do that and which of the drawings you want to see.
Thank you!
Nachricht 7 von 20
Just attach your RVT to a reply post.  You'll see the "Attachments" option if you scroll down below the text portion of the reply post.
Nachricht 8 von 20
Let me try it again.  What are the different combos?  Do you have a combo with the bottom of the view range = Unlimited?
Nachricht 9 von 20
ennujozlagam
go to your roof plan view, try to activate your bulb icon, it could be hidden in the view and unhide element?
Nachricht 10 von 20
RDAOU
@joyquilt1021
From what you have stated above, the Walls are obscured by the Roof element. IE: they will not show on the roof plan. Roof elements when placed, unlike floors, they place above the level obscuring all what is below
You have the following options
  • Detach or Extend Walls UP TO Top face of the Roof
  • Use the Underlay option (For the underlay to show properly, you need to set the view range Bottom and Depth to Associated Level with Offset = 0)
  • Use the feature Show Hidden Lines
    1. Set the view Range Bottom and Depth to "Level Below"
    2. Set view to wireframe
    3. Go to view tab >> Show Hidden Lines
    4. Select Floor/Roof Element THEN select walls
    5. Set view back to hidden line
Nachricht 11 von 20
joyquilt1021
als Antwort auf: RDAOU
There is no roof element to be blocking.
I tried the suggestions anyway, except I cannot select the roof if there is
no roof.
Appreciate you trying.
Nachricht 12 von 20
s.borello
Post the model... you will get a solution.
Nachricht 13 von 20
RDAOU
@joyquilt1021
sorry you implied that there is ...
  • can you post the sections you mentioned?
  • Is there anything at all in this model besides the imported CAD?
Nachricht 14 von 20
joyquilt1021
Sorry I left the impression there was a roof. When I go to 'Roof' there
are no walls to draw from.
I do not know how to post drawings here.
There are only the walls, doors, windows, appliances I have loaded. Nothing
has been added but the very basics.
Nachricht 15 von 20
joyquilt1021
als Antwort auf: s.borello
Sorry, don't see how to post on this site.
Nachricht 16 von 20
Nachricht 17 von 20
Let's confirm. You say "There are only the walls, doors, windows, appliances I have LOADED", but have you actually PLACED instances of walls, doors, windows, appliances in 'model space'?   If so, what Level did you place them on, and what is the Associated Level of your "Roof Plan".  That info is in the View Properties.
...Also important, is the Phase of the Views.  That's one of those 33 I sent you above.
Nachricht 18 von 20
joyquilt1021
Answers to your questions:
I have tried the 'bulb' icon for hidden objects but it revealed nothing.
I have *placed* the items. They are showing in 3D. I placed them on
level 1
The associated level for the roof is Low Roof.
The phase is B10-Superstructure.
I tried attaching the drawing through the normal attach files link, but it
is too large to go.
Thank you so much for your patience!
> level 1
Nachricht 19 von 20
Sounds like you are using the OOTB Construction Template.  I'm betting money that this is Phase Related.  Set your Roof View's Phase Filter to "None" and its View Range Bottom and Depth to "Unlimited" - and then Zoom to Fit.  See anything?
Nachricht 20 von 20
dschleuning49PEQ
Make sure your roof lvl isnt the "top" of parapet lvl. Have two separate lvls and then create a new plan that is at the roof lvl, this should show your walls.
