no templates in the app
I just downloaded the Revit 2019 and there is no templates in the app. how can I import templates to the app?
Go to Options=>File Locations and press on the big green plus sign and browse to the Template folder (probably here: C:\ProgramData\Autodesk\RVT 2019). Then drill down into that folder to find the RTE you want.  Repeat as often as you want, to load as many you want.
